Door Gast op woensdag, 31 juli 2013
Antwoorden 14
Weergaven 3.2K
Hello there. I followed the instructions on this thread and fitted a 2012 headunit into my 2007 car. http://www.citybugclub.nl/index.php?topic=12250.msg261696 The radio works perfectly. The problem is there is now no sound in the rear speakers. Someone said this has to be activated by a dealer. The dealer did not know what I was talking about. Would I be able to do this myself? Does anyone have a tutorial? Please help Thank you ------------------------------------ Hello there. Ik volgde de instructies op deze draad en voorzien van een 2012 autoradio in mijn auto 2007. http://www.citybugclub.nl/index.php?topic=12250.msg261696 De radio werkt perfect. Het probleem is dat er nu geen geluid uit de achterste luidsprekers. Iemand zei dat dit moet door een dealer te worden geactiveerd. De dealer wist niet wat ik het over had. Ik zou in staat zijn om dit zelf te doen? Heeft iemand een tutorial? Gelieve te helpen dank u
Bedankt Jan! Ik zag mezelf weer vertalen straks haha!
[quote author=Murcielaygo link=topic=13062.msg265034#msg265034 date=1377261372] Here's a rough translation: I just installed an original 2012 radio with Bluetooth and MP3 in my 2011 Aygo. Made a couple of wiringlooms myself for the mic and USB, bought a Quadlock to ISO harness which I modified a bit. I'll post a schematic and photos later on. As of a short while I've also got the rear speakers working by activading the fader with a (clone) Peugeot OBD-cable (search for PP2000 on ebay (Marktplaats is a Dutch tradingsite)). This works with the Aygo too! It DID require running two wires to the existing OBD-connector. I'm quite happy with the radio, I only need to find a solution for the automatic switchover to Bluetooth Audio (A2DP) the instant my phone connects with the radio as has been mentioned on the forum before. Perfect. Thank you so much! I will get a clone OBD cable and activate my fader finally! Thank you!
Would someone kindly translate this into English Heb net een originele 2012 radio (met bluetooth en mp3) aangesloten op m'n Aygo uit 2011. Zelf wat verloop kabeltjes gemaakt voor de microfoon en usb. Verloop van quadlock naar iso gekocht en een beetje aangepast. Zal nog wat foto's en het schema plaatsen. Sinds kort ook de achter speakers werkend door de fader te activeren met een (clone) Peugeot diagnose kabel (zoek naar PP2000 op Marktpaats) deze werkt ook met de Aygo ! Wel een extra kabeltje van de radio naar OBD2 stekkker moeten trekken. Ben tevreden met de radio, zoek alleen nog een oplossing voor het vanzelf omschakelen naar bluetooth audio zodra de radio verbinding maakt met m'n telefoon. Dit fenomeen is al eerder op het forum besproken.
een aftermarket radio geen oplossing?? scheeld een hoop gedoe
allereerst gegroet aan iedereen dit wordt mijn eerste post, we hebben onze C1 net, wat een slechte audio zeg, goed ben dus begonnen met aanschaffen van nieuwe boxen in dashbord en deur, ga via deze handleiding de radio aan de Can bus hangen en uitlezen programmeren (fader optie aan zetten) doe dit ook met VAG auto's maar weet niet wat ik zal aantreffen bij de C1 weet iemand het programma voor dit geheel, ik ga het eerst proberen met VAG software Radio is daar groep 56 ik zal als het mij lukt een TUT hiervoor samenstellen met foto's enz
Hello there - the radio is now wired to the OBD as described with the helpful diagram posted here. The Peugeot and Citroen dealers refuse to do it as they claim that their diagnostic tools do not work on a Toyota AYGO. The Toyota dealership refuse to carry out the activation as they do not even know what I am talking about! What do I need to do this myself? Thank you
@AYGOFan: As gemer007 mentioned, he just went to the dealer in Eindhoven and they activated it for free. If I were you, just call some dealerships nearby and ask if they can do it for you. If none of them can, wire the wires correctly and ask if they can have a look with their ODBtool if they can see/change anything. @gemer007: Kijk dat is nog eens een service!
Hi It appears that the radio isn't wired to the OBD port. Once it's been wired (correctly) is it just a case of going to a dealership to activate it? Thank you for your knowledge and help.
Ik ben voor de obd naar de citroen dealer in Eindhoven geweest. Daar hebben ze het even gedaan en voor niks. Prima service van Driessen. Het werkt prima. Ik heb er een actieve subwoofer op aangesloten.
Did you actually added 2 wires from the standard cables (or your quad to iso piece) to your OBD2 port? It's not only connecting the regular cables to your radio, you actually need to add 2 wires. This diagram shows which cables you need to add to your ODB2 port. [img width=509 height=600]https://dl.dropboxusercontent.com/u/23101453/OBD2.JPG[/img] There will be standard cables at those odb2 positions already, just combine the new cables with the original. The ODB2 port is below the steering wheel, positioned approx at your right knee. After that, you can connect the pp2000 (or you dealer's tool) to the obd2 and it will probably show you in the diagnostics your fader control now that the radio is connected to the OBD. Kind Regards
[quote author=Nickk_87 link=topic=13062.msg263377#msg263377 date=1375294561] AYGOFan, Actually, the tutorial you asking for is in the same link: http://www.citybugclub.nl/index.php?topic=12250.msg261696 Igo23 managed to activate it by himself, linking an k-line wire and a ground wire to his odb2 port. He then enabled the fader funtion with an (clone) ODB diagnostic tool, the pp2000. I'll think if you wire the radio to your odb2 port properly, your dealer should be able to check with their ODB tool and activate your fader function. I can translate the essential parts of the tutorial for you, but i'll think google translate will work aswel for now;-) Good Luck! [quote author=Nickk_87 link=topic=13062.msg263377#msg263377 date=1375294561] AYGOFan, Actually, the tutorial you asking for is in the same link: http://www.citybugclub.nl/index.php?topic=12250.msg261696 Igo23 managed to activate it by himself, linking an k-line wire and a ground wire to his odb2 port. He then enabled the fader funtion with an (clone) ODB diagnostic tool, the pp2000. I'll think if you wire the radio to your odb2 port properly, your dealer should be able to check with their ODB tool and activate your fader function. I can translate the essential parts of the tutorial for you, but i'll think google translate will work aswel for now;-) Good Luck! Hi, thank you for the response I am certain that the radio has been wired correctly What tool/wiring will I need to connect the PP2000 to the ODB?
Yeah - I stuck it in Google translate, I don't speak Dutch. Anyone care to help?
