Door Gast op zaterdag, 30 juli 2011
Antwoorden 5
Weergaven 1.3K
Hi I hope to get help with some questions about airbags in our cars. I had planned to install water temuratur, and even a clock in my A-pillar. What about the air bag in the a-pillar? Since I am interested about to replace my seats, the sports seats, What should I consider when I remove the original seats? thanks in advance David
I mean THIS topic.... Okay, not specific about changing the seats, but that's where I found the info I gave you...
If you want to make something onto your A-pillar you'll have to make it in a way that the A-pillar trim can still fold away when the airbag deploys. There's a reak-away clip in the middle that allows the trim to get away from the A-pillar without flying through the car (into your face), so you'd have to construct everything onto the trim, without screwing into the actual metal of the A-pillar. And you'd have to make sure you don't come too close to the windshield too, as doing so might make it impossible for the trim to separate properly. As for your search: seat is "stoel" in Dutch, so maybe you can search for a topic and read it with Google Translate? Unfortunately for you Wouter is wrong in saying that there's a topic on this. There ARE however several people who've replaced their seats, so you might get inspiration from those. A couple from the top of my head: Franzz, ****, wvz, EJS and Mechanx. Do a search in the showrooms...
Back again! I don't know if you have side airbags in your frontseats, but if so you need to "fool" the airbag sensor/transmitter under your seat by putting a 2.2 Ohm "resistance" on the yellow cable.. Here's a link to an album of user c1bries who put other seats in his bug and made a photo instruction of it... : Click!! Hope this helps you and if the info is not sufficient, I'm sure there'll be other forum members who'll be willing to help you out!
[quote author=Wouter K. link=topic=8740.msg189757#msg189757 date=1312010886] Hi David, Concerning the airbag in the A-pillar I can't answer you since I didn't even know our bugs are available with curtain airbags.. (Mine doesn't have it anyway...) About the seats there's a whole topic on this forum but I can imagine it's quite hard for you to find since -surprise!! ;D- it's all in dutch.. I'll have a look in that particular topic and i'll try to translate it for you.. So...i'll be back!! Many thanks to you. I appreciate it
