Door Gast op woensdag, 06 mei 2015
Antwoorden 10
Weergaven 2.7K
Hello all (sorry I can't speak dutch...!) Here's my 2007 Supercharged Toyota Aygo: [img width=800 height=600]http://i40.tinypic.com/15oyyoj.jpg[/img] [img width=800 height=600]http://i40.tinypic.com/2m4cf4h.jpg[/img] [img width=800 height=600]http://i41.tinypic.com/5try29.jpg[/img] [img width=800 height=600]http://i41.tinypic.com/14o242w.jpg[/img] At present it has approx 125bhp at the wheels with 140 at the fly. Spec is as follows: Rotrex Supercharger Conversion Bilstein lowering springs Upgraded brakes Custom exhaust system Aluminium strut brace Lightweight Team Dynamics wheels Sparco Seats 2013/2014 Facelift Interior and Radio Upgraded speakers Thanks for looking
Very nice car. It's quite a project to add a supercharger and tune the engine to get the maximum out of the new hardware without melting anything. Is the boost 0,7 over the regular intake manifold pressure? If adding factor 0.7 in airmass per combustion has twice the poweroutput as a result your ignition must be very agressive. What precautions have been taken to prevent the engine from knocking? Did you lower compression?
Welcome nice bug 8)
Thats's a nice sound - like it
Nice!
very nice bug. I think also Expensive wit al the extra cost to make the bug safer. nice to race on the high way,surprised by a bug ;D
wow amazing bug have there, that sound is sick
Also here's a video of what it sounds like (this was after a long drive and not a cold start!) http://www.youtube.com/watch?v=dTgRIbFGx0k
[quote author=**** link=topic=15606.msg299535#msg299535 date=1430910312] Very nice but can you tell us a little bit more about the super charger install? Has the ECU been remapped? Do you still use the standard pistons? Did you change anything to the fuel injectors? What is the diameter of the exhaust and do you still have the catalyc converter? Do you have a dyno graph because it is hard to believe that you doubled your power by just adding the super charger. Yes the ECU and the car uses an AEM FIC. The pistons are standard. Boost is 0.7 I do have a dyno video but it shows as around 118bhp at the wheel but the car was incorrectly mapped and went back into the dyno the next day and got 123. It also had heavy wheels on at the time of the map so it has a bit more at the wheels now perhaps. I'll dig out the dyno chart if I can find it as the work was carried out on the car nearly 2 years ago!
Awesome!
